Hello, Creo seems to have problems accepting the license. I have done digging here already and found the code BE110908EDSTUDENTEDK12. This has not worked and give the incorrect file type or location error. Not sure what the problem is so any help works.
Thank you in advance!
to get valuable information please provide detailed steps you have done.
I am having a similar issue with the Education License. When trying to open the software I get the attached message.
license file mentioned in uploaded picture contains Creo Parametric 8.0 license.
Please read following documents carefully and follow the procedure described in them.
https://apps.ptc.com/schools/references/install_creo11_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo11_unistudent_standard.pdf
