FYI ... documents available on following URLs contain identical product code BE110908EDSTUDENTEDK12.
https://apps.ptc.com/schools/references/install_creo11_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo11_unistudent_standard.pdf
I found this while answering https://community.ptc.com/t5/PTC-Education-Forum/Creo-11-student-Instalation/td-p/952761 question.
Hi Martin,
That is what I intended to do. The old student code would not allow students to use the commercial files and many of the formats and other common files are in commercial format. Functionality is exactly the same.
Creo 11 is ready to be released, all licenses tested, we are in the process of changing the web pages to allow students access to the Creo 11 guides.
~Alex
Hi Martin,
~Alex
so starting with Creo 11, students (both K12 and University) will use a single product code ... BE110908EDSTUDENTEDK12.
