Creo 2.0 and 3D connexion mouse
  • March 2, 2014
  • 3 replies
  • 8137 views
I have Creo 2.0 student license and working good.
When I have install 3D mouse ( http://www.3dconnexion.com ) Creo not working any more.
I need help how to fix this problem.
Thank you for help
    Hi Anej,
    Can you confirm that everything is working fine when the mouse is not plugged in? This is a very interesting error, and I am looking into it.
    Thanks for bringing it to our attention!
    Hi!
    Thank you for your help - both.
    Creo has worked well until I installed the 3D mouse. Now i have installed 3D mouse and Creo not work.
    I deleted the 3D mouse and Creo working good , but now i can not use 3D mouse
    Hopefully mark will get you an answer very quickly.
    I think that this may help, but no guarantees. Try opening file --> options --> general --> navigation --> select PTC CREO from the drop down box next to the Navigation tag and check "enable use of 3dConnexion Devices" and "keep selection when swtching between figures" boxes then click "OK". You may need to shut down CREO and re-open it for the changes to take afffect, but hopefully this will resolve the problem.
    I don't find that.
    Where I need to do that in Creo or in mouse software?
    I have tried to uninstall 3D mouse and Creo works good (no problem), afert that i install back 3d mouse and Creo not working any more (same problem like on photo).
    Conclusion:
    3D mouse wireless not working with Creo 2.0 student edition
    Any one have solution for my problem??
