.- Joe.
try manual configuration (backup original files before replacing them).
look for C:\Program Files\PTC\Creo 3.0\M070\Common Files\text\metric_config.pro
copy it to C:\Program Files\PTC\Creo 3.0\M070\Common Files\text\config.pro
look for C:\Program Files\PTC\Creo 3.0\M070\Common Files\creo_standards\config_files\appearance_orig.dmt
copy it to C:\Program Files\PTC\Creo 3.0\M070\Common Files\graphic-library\appearances\appearance.dmt
MH
MH
Thank you Martin.
That solved the problem.
Much appreciated.
- Joe.
