Creo 3.0 student edition license expired, Product code Re-Licensing doesn't work
fbaldini
Hi everyone,
my license for PTC Creo Parametric 3.0 expired so I followed the instructions in the 'Re-licensing guide' as here linked http://apps.ptc.com/schools/references/relicense_creo3_schools_standard.pdf. I wrote the Product code in the PTC Installation Assistant dialog box, clicked install and entered my user and password. Once verified the code there is a red error message: "invalid product code". Why do I have this problem if I closely followed the instructions above?? What could be the problem with the copied product code?
ChrisCarr
(To:fbaldini)
Francesca,
It might be an issue with the guide. Try this one: BE400407EDSTUDENTEDK12
Chris
9 REPLIES 9
ChrisCarr
(To:fbaldini)
Hi Francesca,
Make sure the product code is typed exactly the same, including all capital letters. If you copied and pasted, make sure there isn't an extra space at the beginning or end.
Chris
Hi Chris,
I tried more then twice. I copied and pasted with carefully attention for extra space or typed with the capital letters as in the guide, always the same invalid product code error.
Thanks for answered me
Francesca
ChrisCarr
(To:fbaldini)
Francesca,
What's the product code you're using?
Chris
Chris,
I copied the one in the re-licensing guide linked before. Is it wrong I'm using it??
Fra
ChrisCarr
(To:fbaldini)
Francesca,
Chris
Thank you so much Chris!!! Finally it works!! Your code is good!!
Francesca
Hi Chris,
         I just copy pasted the code into the field. It says Error!. IT didn't succeed in installing license. Any help?!!
aabdulkarim
(To:bpanchal)
Hi Bhavesh,
If you are trying to relicense Creo 3.0 University Student Standard, please use this licenes code:
BK400407EDSTUDENTUNICL
Abdul
Thanks Abdul,
The code you provided worked for me. But how to find that code again after 1 year when the license expires?.
Thanks a lot Again.
