Hello! I installed the educational version of Creo 5.0, but I had problems with it. The problem is that, roughly, the license itself does not want to recognize. In the manual, I’ve done everything, and still I don’t have anything. I stopped it several times, but it still did not help.
The license itself took from the instructions:BE410708EDSTUDENTEDK12
In the program itself it gives me this: Here is
Then I decided to enter the installer or the utility, but it still did not help, although the license
shows.
Then I decided to enter the installer or the utility, but it still did not help, although the license shows.
This solution to this problem or where I have not found, and do not even know what to do as I am at a complete impasse. The instructions did not say a word about this problem, and there was not even a hint of anything. As I didn’t do it anyway, I got into an unpleasant situation as the program itself refused to start, and that’s all. I restarted many times, and as you can see, it didn’t help me anyway, and even demolished the license and installed it again.
Please help solve this problem!![]()
please do following:
