I installed Creo 6.0.2.0. I keep getting this error message and shuts off when I click OK. There was never an older version of Creo installed in this computer.
did you follow procedure described in https://apps.ptc.com/schools/references/install_creo6_schools_standard.pdf -OR- https://apps.ptc.com/schools/references/install_creo6_unistudent_standard.pdf ?
What Product code did you enter during installation ?
I am also following this as have same problem, followed the pages to the letter but the licence I was sent says creo parametric 5.0 how do I get version 6.0?
I am sorry I do not have any "magical" advice.
During Creo installation you have to follow 2 basic rules:
K-12 students can use Product code BE600908EDSTUDENTEDK12
University students can use Product code BK600908EDSTUDENTEDUNI
Thanks is this same code to use as an educator as am not a student?
I am sorry I can't answer your question. If you have your personal educator product code for Creo 5.0, then you can send email to Abdul Abdulkarim akarim@ptc.com and ask him how to get personal educator product code for Creo 6.0.
If you are a K12 Educator, you can also request Premium Creo (see the link below). In case Schools edition is enough for your needs,feel free to use the Standard.
https://www.ptc.com/en/academic-program/academic-products/free-software/k12-educator
Alex
tried everything and when setting up via setup as an administrator then the install window opens and loads in everything until the finish button comes on, there is no request for licence or any icons to open up anything at all.
That means that the license exists on the computer... So what is the issue?
Alex
What is the error message stating? Please expand the window and tell me what it is the full message so I can understand what is wrong.
Alex
Can you expand the message window so I can read all the text and post here a picture?
The license you installed is for Creo 5.0 and not for Creo 6.0.
You need to run setup.exe and use the correct product code for Creo 6.0:
Alex
I think I will try to delete all the files and reinstall it.
