Creo 7.0 Student edition Licensing Failure
AB_9625135
3-Newcomer
After I input the licence key it shows "success" and also says "invalid file or format". I have attached ip.txt.
8 REPLIES 8
Please, How can I access the licence code for this edition
please upload license file(s) located in C:\ProgramData\PTC\Licensing directory.
Martin Hanák
Here it is. (The file had extension .dat I have changed it to .txt)
The file seems to be empty. Please delete it, run setup.exe in admin mode, select reconfigure existing software and use this product code:
BE700908EDSTUDENTEDK12
Alex
Did that and the same result.
I suspect the installer has a problem finding the correct network card.
My suggestion - disable following network cards:
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : C8-D3-FF-91-AD-9B
Wireless LAN adapter Local Area Connection* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 96-E9-79-BA-4D-E5
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 94-E9-79-BA-4D-E5
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 94-E9-79-BA-4D-E6
The only network card will be:
Wireless LAN adapter WiFi:
Description . . . . . . . . . . . : Realtek RTL8723BE 802.11 bgn Wi-Fi Adapter
Remove all files from C:\ProgramData\PTC\Licensing directory.
Install Creo onve again.
Martin Hanák
i also faced the invalid license format. so i tried the ip.txt that also not working
Possible solutions for "Invalid file or format" status under License Summary while installing Creo: https://www.ptc.com/en/support/creo-admin-troubleshooter/other-symptoms/invalid-file-format
