when I open Creo parametric the program exits this screen. I have already tried to find a solution for th esame issue.
thank you
thank you
you cannot run Creo in Windows Terminal Services client window.
it may be because I use a remote connection for use creo?
thank you
thank you
yes, you are right. Student license is not available when you connect using remote connection. If you connect using Teamviewer it will work (I hope).
