I recently installed the creo student version and when I started using it after just drawing 1/2 curves and making a basic solid the programs goes into not responding mode. it resumes after a min or two and then again goes in to not responding once I click just 1 feature to edit.
My system deets are -
Processor Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz 2.81 GHz
Installed RAM 16.0 GB (15.9 GB usable)
System type 64-bit operating system, x64-based processor
Windows specifications
Edition Windows 10 Home Single Language
Version 20H2
Installed on 11-04-2021
OS build 19042.928
Experience Windows Feature Experience Pack 120.2212.551.0
Version 20H2
OS build 19042.928
start Task Manager and check whether some application is running hight during Creo "no reponse" period. Also check disk activity.
The task manager has no other processes running when creo is running except for the brave browser and combining both of them the RAM usage barely hits 6 GB out of 16 GB. Plus I have disabled all the startup process that might hinder the ram usage. The CPU usage also hits around 5% when creo goes in not responding mode.
PS. If you are wondering that my C: drive is full then it's not I have 30 GB of free space.
Hi.
my last tip ...
Add following option into config.pro file, start Creo and test its functionality.
graphics win32_gdi
Hey, thanks for the suggestion but the option you suggested still doesn't work for me.
