Creo 8.0 Render window
SimonHooker
9-Granite
Hi All,
Have just installed Creo 8.0, but when I load up the render window, it comes up as a small square in the centre of the screen. Creo 7.0 works fine and no issues.
@SimonHooker wrote:
Hi All,
please publish pictures.
Martin Hanák
@SimonHooker wrote:
FYI rendering works well in Creo Parametric 8.0.0.0 on my PC.
I guess your problem could be caused by old graphic card drivers.
Martin Hanák
It works fine to create a Jpeg. file of the render and is fine when real time rendering is turned off. Not a Huge issue I guess as use Keyshot for most of my renders anyway. Thanks for trying I'll have play about with the graphics card and see. Not sure why Creo 7 is ok by 8 is not, unless the rendering application has been modified.
Simon
