I have loaded Creo 9.0 K12 Student edition on our computers at school and I ran across something later on that mentioned config file that should be used for the How To Model Almost Anything curriculum. Where can I get that config file so the software loads like the curriculum is expecting?
Quote: "To make this curriculum and your introduction to PTC Creo easier we have developed a set of custom configuration and user interface options for
you. If you do not apply this configuration, then the instructions in How to Model Almost Anything will not match your screen. For information on how to download and install this PTC Creo configuration, please see the below guide: http://apps.ptc.com/schools/references/config_creo_schools.pdf ".
Thank you. That is just what I was looking for.
You're welcome.
