I am trying to install my software and I am encountering the issue described here (Re: Problem Installing Pro/E Schools Edition WF 5.0). Is there a way to get the disk image of the software?
Jeff DeLong
Unfortunately, Creo Elements/Pro 5.0 (Wildfire 5.0) is no longer officially supported by PTC. This is due to following a normal product retirement cycle on previous releases of software. I would recommend that you upgrade to Creo 3.0 (the most recent version) through the PTC store: https://store.ptc.com.
Alex
Alex
