Creo Installation Assitant doesn't open
AZ_10979403
3-Newcomer
I downloaded the needed, but when I try to open setup.exe, the creo installation assistant doesn't open
I turned off the antiviruses, and ran it as an administration, but it just doesn't open
The version of Creo I downloaded is 9.0 student edition
@AZ_10979403 wrote:
the laptops graphic card is nvidia 3070
I do not see any problem.
1.] try asking Google ... windows 11 creo parametric 9.0 setup.exe
2.] run setup.exe from Command prompt window (path to setup.exe must not contain spaces and special national characters)
3.] open Event Viewer and look for error message related to setup.exe
Martin Hanák
4 REPLIES 4
disabled all protection and deleted previous licenses, ran the setup.exe as an administrator and it just doesn't open
please provide following information:
  • detailed hardware configuration
  • Windows version
Martin Hanák
Martin Hanák
