I purchased the Creo 10.0 Student Premium version to be able to use the full extent of the advanced framework extension. When I use Advanced Framework, I am limited to 20 features and receive a popup stating that I am using AFX Lite. All of the information I can find seems to suggest that I should receive the full version of advanced framework with the premium version:
Creo9_Education_Editions_Comparation_Chart.pdf (ptc.com)
(I cannot find a similar chart for Creo 10.0. A google search of "Creo education editions comparison chart" returns a pdf link that shows the same: The free student version includes AFX Lite while the paid premium version contains the full AFX extension.)
Creo 10 University Student Edition Premium License | PTC Store
(under Key Features, Advanced Framework Extension is listed, with no suggestion of it being the LITE version)
It appears that the Manikin extension is working properly so I think some of the features of the premium version are active. Therefore, I don't think I am using a license for the standard student version.
I have uninstalled and removed the previous licenses twice and still have the same results.
click File > Help > System Information > System Information
... and search for Advanced Framework
Also you can check the contents of your license file.
Search for code 213 ... it belongs to Advanced Framework.
In my license I can see it:
INCREMENT PROE_DesignPrmP ptc_d 41.0 date qty \
xxxxxxxxxxxxxxxxxxxxxx VENDOR_STRING="VSVER=2.0 \
LO=(0,3,6,7,10,17,26,32,34,40,45,48,51,52,55,56,57,59,61,62,63,66,67,69,71,73,91,92,94,97,104,106,108,115,116,125,126,127,128,131,133,135,137,158,163,188,191,192,194,213,219,220,251,275,277,278,282,291,292,324,325,326,327,329,331,332,336,341,346,347,354,357,361,370,371,372,374,375,376,377,386)
Thank you,
I do not see it in my System Information, and I also do not see it in my license file. I have contacted support to resolve this issue as it is clearly advertised on the product listing.
