Creo Parametric 2.0 System Table Folder for Student Edition
sm
If you are having difficulties loading the Quick Table menu or using the inserting a TBL file from the System Tables folder with the Student Edition of Creo Parametric 2.0, the attached ZIP file should remedy the situation. This problem has already been resolved in Creo Parametric 3.0 and does not require this update.
  1. Close any open Creo Parametric sessions
  2. Download the ZIP file to your computer
  3. Unzip to your computer so there is a single folder named table with the subfolders; Assembly, Cabling, Diagram, Format and Manufacturing
  4. Navigate to your Creo Parametric installation folder
  5. Open Common Files\M120\text, where M120 is the datecode of your software
  6. Rename the table folder to table_OLD
  7. Copy the extracted folder to this location
  8. Start Creo Parametric and create a new drawing and place a system table on the sheet
               - New, Drawing, Empty, OK
               - Table, Quick Table
               - Drop a table on the drawing
0 REPLIES 0
