If you are having difficulties loading the Quick Table menu or using the inserting a TBL file from the System Tables folder with the Student Edition of Creo Parametric 2.0, the attached ZIP file should remedy the situation. This problem has already been resolved in Creo Parametric 3.0 and does not require this update.
- New, Drawing, Empty, OK
- Table, Quick Table
- Drop a table on the drawing
