I'm a student using Creo 2.0, and have had this program for months without any issues and then all of a sudden I get an error upon oppening Creo:
"License request failed for feature"
I attatched a picture of the full error message.
I don't know if it's an expired license or what. I thought I read that the student licenses never expired? I'm not sure, but thanks in advance!
After you post, check you message again. On the right side of the screen will be suggestions for similarly named posts or posts with similar content; for example http://communities.ptc.com/message/212087#212087 which may be what you need to continue.
That link did point me in the right direction.
It ended up simply being an expired license. Contacted support and everything is good in the world.
