Creo Parametric 3.0 M070 invalid license
gtrejo
I download and installed Creo Parametric 3.0 M070. When I try to run the program, the Warning Message List appears, saying "License request failedfor feature"
The license I received by email is, BK309206EDSTUDENTUNICL
Thanks for you help.
regards,
Gerardo
MartinHanak
(To:gtrejo)
your license enables you to run Creo Parametric 2.0 ​only, because its version is 33.0. You need to get license with version 34.0.
MH
Martin Hanák
Hi Gerardo,
I believe you have received the wrong license. Below is the installation guide of Creo 3.0 University Student Standard. Please follow the steps to install it.
http://apps.ptc.com/schools/references/install_creo3_unistudent_standard.pdf
Abdul
Thanks so much Abdul! This email solved the problem for me.
Gerardo
