Creo Parametric 8: Mechanism
DS_10290721
3-Newcomer
I want to simulate my designed pneumatic gripper. It works with a pneumatic cylinder. I want to move this pneumatic cylinder with the tool "linear motor". The motor should simulate the compressed air which can be turned off and on. A compression spring works against the motor (in real: pneumatic cylinder). So when the motor (in real: compressed air) is turned off, the spring pushes the piston back. How can I edit the linear motor that it turns off and on automatically every to seconds and how can I edit the linear motor that it can be turned on and off by myself whenever I want?Screenshot 2025-07-08 213955.png
Hi @DS_10290721
Thank you for your question.
Best regards,
Catalina
PTC Community Moderator
PTC
