My computer runs windows 7 64 bit and meets all of the specifications for Creo.
I have my product code, but everytime I run the setup wizard to generate the license it returns this:
A failure occured during license generation.
An unknown error occured requesting a license file be generated from ptc.com
I am using this software in an engineering elective at Univerisity of Alabama Birmingham.
Hello Josh,
i do not see any reqiests from you...can you please email me your PTC HOST ID and will create the license file for you.
thanks
Dima
Try to conract with "PTC Academic Support": http://www.ptc.com/go/academic-support
still having the same problem, contacted academic report several days ago and still waiting on a reply.
Hello Josh,
thanks
Dima
Good day, Dmitry
I downloaded Creo Parametric 1.0 Schools Edition quite sometime back. I had sent request for the lisence file, however no reply from anyone to date. Is it possible for you to create a license file for me, if I give you my PTC Host ID?
Sivaroopan
Hello, i also meet the same problems.
Can you help me to solve it?
Plz.........
Please contact the Academic Support team: http://www.ptc.com/go/academic-support
I'm having the same problem, and was wondering how I can get in contact with the Academic Support Team. I can't find an email address.
All Academic support should go through our PTC Academic Support page where you can find a solution yourself or submit a support request from the bottom of the Request Academic Support tab.
Thanks, Adam. I appreciate the help.
