Creo University Edition
MM_14430813
2-Explorer
I am installing Creo University edition and I entered BK120908EDUNIVERSITYED under sales number order or product code. It didn't go through and displays ERROR in red.
1.] BK120908EDUNIVERSITYED is Product code
2.] You can contact academicsupport@ptc.com (via e-mail). You need to send them the Host ID (Mac address of the ethernet) and also the product code used. I hope they will send you valid license file.
Host ID ... this means physical address of network card
  • if Ethernet network card is installed in your computer then use its physical address
  • if the only network card is WiFi network card then you must turn off MAC address randomization to get real physical address
Martin Hanák
Martin Hanák
Thank you, this worked.
Hi @MM_14430813
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
Thank you
