uninstall PTC Creo 4 Platform Services item ... and reinstall it using creosvcs_64.exe available in Creo 4.0 installatin package in install\addon sub-directory.
Hi Martin,
I have the same issue. I tried uninstall and install again but the issue is the same. I saw that "Agent" folder is not created in the installation. This issue happen on Creo 4.0 M040.
I have the same issue. "uninstalling PTC Creo 4 Platform Services item ... and reinstalling" did not work.
Any other suggestions?
Same. I'll join the queue too. Any solutions?
found the solution?
I got this corrected with help from PTC. There are number of reasons that could cause creo agent to fail. Main reasons being anti-virus not upto date, Windows patches, non-compatible IE. Try fixing this all, uninstall all creo related software comes with the package and reinstall it again. It should work.
I get the same problem.
Did you resolve it ?
Thanks ^^
Yes. I got this corrected with help from PTC. There are number of reasons that could cause creo agent to fail. Main reasons being anti-virus not upto date, Windows patches, non-compatible IE. Try fixing this all, uninstall all creo related software comes with the package and reinstall it again. It should work.
Did you re-download it or just uninstall it?
