Whenever I attempt to open Render Studio, the program will stop responding. I am only having issues with a particular part. Any other part has worked fine. What can I do to fix this? I have to submit renders of this part for a project. I tried to leave the window open for 20+ minutes but it never loaded into render studio.
Using Creo Parametric 11.0.0.0
I am trying to upload the part, but it says that file type .1 is not allowed. What am I doing wrong? In file explorer, it just shows as .prt.
Thanks!
I ended up needing a stronger graphics card. I was using a laptop 4070 but it was not strong enough.
Articles:
