Software not launching due to licence error, now I'm trying to licence identification again what should I enter in product code right now.
Previously I used -
BK900908EDSTUDENTEDUNI
This product code.
at the end of PDF file you can see following information...
This means that product code BK900908EDSTUDENTEDUNI belongs to Creo 9.0.
To install Creo 10.0 please use https://apps.ptc.com/schools/references/install_creo10_unistudent_standard.pdf instructions.
Do not forget to remove all license file from C:\ProgramData\PTC\Licensing directory before you start Creo 10.0 installation.
It worked, Thanks a lot.
