I am having a problem with the Creo 8.0. It gives me a fatal error when I try to open an assembly I made prior. I have followed the steps by the following link on download config.pro as well as change the content in it. However, the system still gives me the fatal error.
How to Fix "Fatal Error Encountered. A traceback ... - PTC Community
Please let me know how I can fix this issue. Thanks
My system automatically updated .NET the day prior to I use CREO. I am not sure if .NET version difference could cause the issue. However, after I uninstall and reinstalled the CREO 8, everything seems to be working again.
Could you try to update .NET? It seems that your trackback is referencing an issue that is related a .NET outdated version.
Also in case you are using Windchill you may need to clear the cache and try again.
Alex
