Creo parametric 8 doesnt open after installation
VB_10288820
3-Newcomer
Information regarding the system:
Macbook air M1 running windows 11 in parallels.
Creo 8 education license
The problem:
Creo does not open, after installation. It just does not do anything and also does not pop up in the Task Manager. Whilst installing the installation manager complained, that he could not install Visual c++ redistributables. I finished the installation never the less, because under programs, in the system preferences, all the redistributables for visual c++ are listed.
I tried all the other helping tips and tricks that helped others with similar problems. Does anyone have an idea, what the problem could be?
12 REPLIES 12
The problem:
tip no.1
Add following option into config.pro file
graphics win32_gdi
tip no.2
Try Windows 10.
Martin Hanák
First of all thanks for the help. Sorry for my late reply, but I had some other things I had to take care of first.
The tip no. 2 unfortunately does not work in my case, because windows 10 is no longer available for ARM in Parallels. Which means I have to use windows 11. Regarding the first tip: I have found the config.pro file, but how do I add the option "graphics win32_gdi" ?
ARM processor is not supported platform.
Martin Hanák
thx for the answer. But why am I able to install Creo without any problems? Yes, there is a warning about certain parts of the suite not compatable, but the rest should work, right?!?
I think that you can install Creo because installer is able to run on ARM processor.
Please go to https://www.ptc.com/en/support/refdoc/Creo_Parametric/9.0/creo9_hardware_notes page and open PDF document https://www.ptc.com/support/-/media/support/refdocs/Creo_Parametric/9,-d-,0/creo9_hardware_notes.pdf?sc_lang=en .
You will see following information:
Martin Hanák
Unfortunately doesn't work for me, because Mathcad is the only program I can choose, which doesn't help me in this case. Thx though
Status update: I installed the latest versions of visual c++ and reinstalled Creo. That had the positiv effect that the installation went nearly perfect this time. The Warning regarding visual c++ is gone and it installed that part like it should, there was only a warning regarding creo topology or something like that.
Unfortunately the problem remains. It does not start.
Hello, I'm having the same issue. Running Parallels with Windows 11 ARM. It installs fine but it does not start. Any pointers?
hi, have you some news? I have the same problem and I wanna know if you solve it, thanks!
what news do you expect ? ARM platform is not supported by Creo. Creo will not run on ARM.
Martin Hanák
