Does "Goto Sheet" functionality still exist in Creo 2.0? Would be helpful for very large fixture drawings 50+ sheets. Old mapkeys no longer work, so I am assuming this functionality may be gone. Does not show up in the Command Search tool.
There's a tabbed interface with "play" buttons. I don't see the old "Switch Sheets" command though.
Wow, that's a heavy duty drawing for a FIRST robot. The funcationality is the same in Creo, except you can use the new sheet tabs in the Creo UI or simply double click on the text "SHEET N of X" at the bottom of the graphics window to bring up the Go to Sheet box as you did in previous releases.
thanks
