Download link not working
rautadi11
Please see the screenshots as the link is showing this!!!
An error has occurred
Please save the source of this page (File: Save As...) and email to webmaster@ptc.com
Thank you for your help in resolving this matter.
PTC Webmasters
21 REPLIES 21
Nitish98
(To:rautadi11)
Even i am getting the same error for creo5.0 STUDENT edition, please help
temeteron
(To:rautadi11)
Same here...
I emailed the error to the webmaster as requested in the error page.
Please fix, thx.
Pyrokav
3-Newcomer
(To:rautadi11)
I have the same problem it's impossible to download any Creo version.
Please, did you find a solution?
Thank you
It is a problem with the server we are looking into resolving it ASAP.
It works for PTC internal accounts, but not for any external account, that is why I gave you the instruction to use HTTPS.
Alex
Please press the HTTPS and not the Download Manager.
Alex
rautadi11
(To:Alex_Cazacu)
Please tell me how to go on the page which you shared the screenshot of?
Please attach step by step help with screenshot or screen recording just like I did.
temeteron
(To:Alex_Cazacu)
Would be helpful if you could share the link, as this is not what we see when following the process steps, we land on a different page. Thx
RrRr
3-Newcomer
(To:Alex_Cazacu)
www.ptc.com/appserver/auth/it/esd/academicFree.jsp
This link is not working at all EVEN after I logged in
Nitish98
(To:Alex_Cazacu)
To get to that page we have to access this link
http://www.ptc.com/appserver/auth/it/esd/academicFree.jsp
but this link is not working at all, please help
Guys,
Until we solve the issue with the server here is a direct download link for Creo 6.0 that will work until the server is back:
http://apps.ptc.com/schools/references/MED-100WIN-CD-430_6-0-3-0_Win64.zip
Alex
Nitish98
(To:Alex_Cazacu)
could you please send a download link for creo 5.0 , thanks
Yes that would really ahelp a lot.
Here is a link for Creo 5.0:
http://apps.ptc.com/schools/references/MED-100WIN-CD-420_5-0-4-0_Win64.zip
Alex
Hope you'll solve the problem with servers quick.
Your direct link doesn't work correctly for me. My downloading stops after few minutes with information that there was some network problems. I don't know the reason, maybe it's something on my side.
I think normal link will work for me well.
rautadi11
(To:Alex_Cazacu)
I've downloaded the file and after unzipping I also installed it. After running the application Creo Parametric I'm getting a message on the screen that "Licence request failed for the feature". Please the screenshot for better understanding.fail.jpg
rautadi11
(To:rautadi11)
@Alex_Cazacu  Please see this error.
What should I do?
The product code you used is for Creo 5.0 and not 6.0, so it will be unsupported. Correct product code for Creo 6.0 is: BK600908EDSTUDENTEDUNI
Go to C:\ProgramData\PTC\Licensing and delete all the licenses.
Run setup.exe again, but choose reconfigure existing... in the licensing window use the product code and make sure that after using it you see the license under license summary as available. finish the installation.
Alex
Eli1999
3-Newcomer
(To:rautadi11)
When following the link; http://www.ptc.com/appserver/auth/it/esd/academicFree.jsp to download the software. You are greeted with an ERROR message. I need to download CREO 6.0 for my Mechanical Engineering assignment which is due soon. Please if you could fix this soon, it would be greatly appreciated. You find this ERROR message only when trying to download the file. I have attached the source file within an email and have sent it to; webmaster@ptc.com as instructed by the error message.
Kind regards,
Eli Obeid
there is a temporarily link on the other thread. Please check first the other topics on the same issue before posting again.
Alex
The server issue has been resolved! All functionality is back!
Alex
Nitish98
(To:Alex_Cazacu)
Thanks for your support 🙂
