Hi all,
I am currently running thermal simulations in Creo parametric 10.0.0 and I am trying to use point measures for maximum temperature through my model (section view with points attached below).
However, the point measures which are within the body of the model show 0 C for the entire simulation in the results window (the surfaces point measures are working perfectly fine). Is there a correct/different method to set-up point measures within the body of a model?
Thank you in advance.
Hi KP_10875782,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry. Which version of Creo are you using, is it Student/Educational or Enterprise?
This will help us understand if the question is posted on the correct board firstly. It should increase your chances to receive meaningful help from other Community members.
Community Moderation Team.
