Error importing .iam file from Autodesk Inventor into Creo 9.0
LH_11210795
2-Explorer
Does anyone have a solution to this?
https://www.ptc.com/en/support/article/CS134024 document tells that:
  • Creo 9.0.0.0 can import R11 & 2008 to 2022
  • Creo 9.0.3.0 can import 2023
  • Creo 9.0.7.0 can import 2024
This means import 2025 is not implemented.
Martin Hanák
3 REPLIES 3
I don't know if this matters, but it is Autodesk Inventor 2025.
Martin Hanák
Hi @LH_11210795,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
