https://www.ptc.com/en/support/article/CS134024 document tells that:
This means import 2025 is not implemented.
I don't know if this matters, but it is Autodesk Inventor 2025.
Hi @LH_11210795,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
