I am unable to constraint gas spring on both sides. At the upper side the pin type constraint is applying correctly. However, at the below part the pin constraint is not being applied. I have assembled the gas spring with cylinder type constraint. Any suggestions?
The screeshots are attached with the post.
Thank you for your response in advance.
