Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
When will the parts for FTC be available? Our team is just beginning to discover CAD drawing, but are waiting for the parts. It would have been wonderful to have them MUCH earlier in the season, but we would be happy to have them as soon as possible. Our last competition is in Feb. and we would like to be able to model our robot changes before we actually make them. Thanks.
Hi Heidi, They will made available today. You can download the from here http://www.ptc.com/go/firstkop. Click on the FTC 2008 Kit of Parts link to select specific files or just download them all. Thanks, Mark
Hi Keith, I am working with Pitsco (the provider of the Kits for FIRST) to develop a complete kit for the coming season. As for the LEGO parts......we do provide the sensors in the current kit. What are you looking for? Thanks, Mark
I was looking for beams, axles, connectors, etc to connect the sensors or motors. I think I found what I was looking for at the Robotics Academy. http://www.education.rec.ri.cmu.edu/downloads/lego/solidmodel/parts/pro/ Thanks, Keith
Mark, Actually when I tried to load these ProE files it said that they were created with a commercial version of Pro/Engineer and are not compatible with the version I was running. So I'm still not able to use the LEGO ProE parts I found. Thanks for your help, Keith
