Hi all,
For a project I want to open a model that can be download from the "Creo Flow Analysis Beginners Tutorials" section (the Cyclone Separator) but I can not open because I have the student edition.
Is there a way I can open it with my student edition or another file I can work with ?
you need Academic license to open files created using Commercial license. Maybe such Creo installation is available in computer lab at your school.
WARNING ... I do not think that Student license enables you to run Creo Flow Analysis. Please check whether license file contains Creo Flow Analysis module.
