We’re aware of an issue preventing community login. Our team is actively working on a fix and we’ll share updates as soon as possible.
I am working on galileo gen board 2, and doing a project of weather project. The properties are not getting connected to PTC. I am having a issue on the TWC_Agent, while manually running TWC_Agent, it is showing some errors as "Error trying to connect" & "invalid 'connection' header" and "websocket connection failed". If someone has came across these errors kindly share solution
Harshal, do you have any proxy server in place?
No, there is no proxy server. But I do have a Wi-Fi router, Will that have any effect?
I've seen the invalid upgrade error few times, and it has been with connections involving reverse proxy (as it sends back 2 extra headers). Using the latest version of the Edge MicroServer should fix that.
From Where can I download it. the "Edge MicroServer". I have searched the site, i could not find it.
It is available on the PTC Support site under the Download Center -> ThingWorx Edge Microservers section
I am not having permission to access it can You mail me the zip file of the latest version of "ThingWorx Edge Microservers"
kindly mail me,
email id is "harshaljaurkar@gmail.com"
Harshal, this would probably have to go through sales. Do you have a support account or do you still have the contact information of your sales personnel?
*Edit*
I'll reach out to someone locally here and see if something can be done.
THanks for your help,
Actually my network had the problem, I tried on my friends network, it is working now.
Thanks for your precious suggestions.
Now I am trying to built the mashup.
Do you know the procedure how to make an image visible and invisible for a certain changes in the parameter??
Harshal, generally all widgets have a 'Visible' property that can be bound to. You can enable/ disable (or check/ uncheck) that based on your result.
