During setup the ptc software, I need to input the license number. But I haven't received any license code when I check the email.
let's say you want to install Creo Parametric 11.0. Did you read following documents?
https://apps.ptc.com/schools/references/install_creo11_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo11_unistudent_standard.pdf
Also note, that you can request license file via email. Please read https://community.ptc.com/t5/PTC-Education-Forum/Creo-Parametric-9-0-Student-Edition-Licence-error/m-p/897846 discussion.
