Having problems downloading license
RS_14019455
I recently downloaded Creo 12.0. When I attempt to install the license, after I punch in the code provided by the held pdf, I receive an error message.
@RS_14019455 wrote:
Hello, I did follow the guide, and I did run setup.exe. However, I am still facing the same problem. I am attempting to use the university edition.
you can request license file via email. Please read https://community.ptc.com/t5/PTC-Education-Forum/Creo-Parametric-9-0-Student-Edition-Licence-error/m-p/897846 discussion.
Martin Hanák
6 REPLIES 6
AFAIK Product codes related to Creo Parametric 12.4 was not released. Maybe @Alex_Cazacu can provide more information.
Martin Hanák
You are attempting to install a license server and the code you are using is for a standalone license. Please follow the guide and instead of launching license server run setup.exe.
~Alex
Hi Alex,
Creo 12.0 can be downloaded from https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp page. Unfortunately I am not able to locate PDF files containing installation instructions. I mean something like install_creo12_schools_standard.pdf and install_creo12_unistudent_standard.pdf.
Martin Hanák
Martin Hanák
I have sent the request file, thank you for your guidance.
