Help! Help! Help! Why can't creo lock the vertical/keep the horizon when rotating the view?
Walker
Why can't creo lock the vertical/keep the horizon when rotating the view? it's almost the most important thing in 3D design, otherwise, it feels like you get an imbalance of the inner ear, Is there some reason for great wisdom? how to keep the horizon? please help me!
MartinHanak
(To:Walker)
by default model rotates around spin center in all directions simultaneously.
If you need "something different" you have to use View dialog box ... see attached video.
Martin Hanák
2 REPLIES 2
MartinHanak
(To:Walker)
Martin Hanák
Thank you for your guidance.
