I have a assembly with family table instances as a sub components
Whenever I tried to save a copy of the assembly with new names. The instances are break into seperate components and there is no relation between their generic component.
Please help me to get a solution for the same..
Manikandan S
Look at http://communities.ptc.com/message/225598#225598 for using Creo alone
and http://communities.ptc.com/message/260115#260115 if you are using Windchill.
