I need a help regaridng navigating among mashups
1. i have four mashups
first mash up have three guages ( temperature, humidity, pressure)
second mash up is temperature graphical representation
third mash up is humidity graphical rep
fourth mash up us pressure graphical rep
How can i go from first mash up to second mash up (temoerature ) if i click on guage with temperature in first mash up (guage doesnt support navigation) and vice versa
Sin, you can still use the Navigation widget - set/ check the 'Transparent' property on the Navigation widget and move that onto the top of the Gauge widget (expand the widget to match the gauge's size if needed).
Sin,
Adding to Aanjan Response: you will need either to add a panel before you add the Gauge as you won't be able to add the Navigation Widget on a responsive panel.
You can also use the Frame widget (available in the MarketPlace). Unfortunately this widget did not work in TWX 7.2, but I tried on 6.x version and it worked.
Cheers
Ewerton
