Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Not sure exactly what your problem is, but some of my students have had this problem. ProD aborts when trying an extrude. Solution: Right Click on the ProD exe file and "run as administrator". After it has run once this way, the problem goes away. Something to do with registry and permissions. Hope this helps.
