How to change my CREO 10.0.0's language?
琛鄭_11904668
The  version is CREO 10.0.0 student edition, and I can't find any setting or option that can change language.
It is now in Chinese version, but I want to change it to English version.
I found all the available information, but still can't change it.
7 REPLIES 7
open <Creo_loadpoint>\Parametric\bin\parametric.psf file in Notepad and add following line at the end of it.
ENV=PRO_LANG=English
Martin Hanák
Sorry, I'm not sure which step I did wrong,
but after I opened the file at the location you mentioned and edited it,
it was still in Chinese when I started again. 
Thank you for your reply.
maybe my suggestion was wrong. In my psf files I use following line
ENV=PRO_LANG=usascii
Q: How are you launching Creo? Do you double-click shortcut related to parametric.exe  (see picture) ?
Martin Hanák
Thank you for your reply. After trying once more and rebooting, it is still in the Chinese version. I'm not sure if it is related to my Windows being in the Chinese version.
"C:\Program Files\PTC\Creo 10.0.0.0\Parametric\bin\parametric.exe", This is the target of my Creo.
I remembered the second possibility…
Please add following options at the end of config.pro file.
dialog_translation no
help_translation no
msg_translation no
menu_translation no
See https://support.ptc.com/help/creo/creo_pma/r11.0/usascii/index.html#page/langsupport/Langsupport_configuration_options.html
Martin Hanák
Thank you. I followed the steps, but after opening it, it's still in the Chinese version. Perhaps I should reinstall the software?螢幕擷取畫面 2024-10-10 131531.png
I am sorry I do not have any other idea how to resolve your problem.
Of course you can try reinstalling but I don't know if that will help...
Martin Hanák
