Community login and other support tools will be unavailable Saturday May 3rd 9:00 am to 3:00 pm (EST) due to planned maintenance. Learn More
How to license Creo Illustrate 8 student edition
EJ_10304951
2-Explorer
Hi All,
I have an issue regarding Creo Illustrate 8, After I installed the software Creo Illustrate startup screen appeared. I couldn't find a license file to activate it. Anyone can help me with this please? How can I activate the Student version?
Erandaka.
5 REPLIES 5
Read the following articles:
Hi VladimirN,
Thank you for your kind support. I don't know anything about license server and above information. and actually I don't have a license server name. Could you please tell me can we just open it as a normal software?
Erandaka.
@EJ_10304951 wrote:
Hi All,
Erandaka.
did you receive license file copy via email ?
Look into C:\ProgramData\PTC\Licensing directory. Does it contain license file ?
Case no.1 ... you have license file containing INCREMENT CREOILLUS_STANDARD line
  • set environment variable PTC_D_LICENSE_FILE ... it has to contain path to the license file
  • run Creo Illustrate
Case no.2 ... you do not have license file
  • download Creo Parametric installation zip file
  • unzip it
  • run setup.exe and install Creo Parametric
  • when finished ... you can see license file in C:\ProgramData\PTC\Licensing directory
Martin Hanák
Hi Martin,
Thank you very much, I didn't receive license file through email. And my computer doesn't contain PTC\Licensing folders, I'll install Creo Parametric first.
If you don't mind could you please tell me how can I do this...
Erandaka.
you can find lot of information when you use Google or Youtube. For example:
https://www.youtube.com/watch?v=SvU3zvhEROc
https://www.architectryan.com/2018/08/31/how-to-change-environment-variables-on-windows-10/
Martin Hanák
