Hi ![]()
I accidentally deleted parts of the CREO PTC software. I would like to repair / reinstall. My license is still active. I can't find a download link. How do I reinstall?
Thank you for your help!
your license file is probably located in C:\ProgramData\PTC\Licensing directory. Make a copy of it to be sure that you do not lose it.
Installation media in zip files are available on www.ptc.com/appserver/auth/it/esd/academicFree.jsp page. Login to PTC is needed. I suggest to unzip file using 7-zip application.
1.] Remove your current damaged Creo installation
2.] Install Creo from the scratch
MH
Thank you very much!
Should I use the setup.exe or setup-schools.exe?
use setup.exe and put path to your existing license file into source field. See red field in Re: Can't get license. - PTC Community discussion.
MH
