I am trying to calculate the humidiy , Hence i am using the label chart to display the data .
As part of my project i need to display the month name on X Axis and Percentage of relative humidity on y axis
ex: in the month of JAN (X AXIS) Percentage of relative humidty (60%)
Please and kindly tell me the best chart to use to display my data and how to get the month name at my x axis
Label Chart
create a service that generates an infotable with one field containing the Month Name, and the other the associated Value.
Remember to populate it in order of your months.
Then all data to the label chart, set your month field as X axis and humidity as the Y axis.
I have tried to use non numeric data as axis range without success. As per my understanding you can set only numeric values in X-Axis. So changing the month name to month number might work. Let me know if you find a way to use String values in X-axis.
