INSTALLATION RELATED
PK_10128146
2-Guest
ERROR COMES AFTER STUDENT PRODUCT CODE FOR CREO 7, NO SUCCES MASSAGE INDICATE
Did you use this code - BK700908EDSTUDENTEDUNI from the instructions "PTC Creo 7.0 - Student Edition - Quick Installation Guide"?
rghadge
(To:PK_10128146)
@PK_10128146
Please try procedure mentioned as per http://apps.ptc.com/schools/references/install_creo7_unistudent_standard.pdf and see if it helps.
VladimirN
24-Ruby II
(To:rghadge)
This PDF file is already attached in my post above.
rghadge
(To:VladimirN)
@VladimirN,
Yes, I missed attachments in your post.
