Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
In my installation the visual c++ redistributible folder fails when i setup, all the installations are correct but the program doesn't open. Please I have tried different aproches to try to make it work, with an informatic even an nothing works. Please contact as soon as you can. Thank you!
