I followed the instructions and entered the license code BK800908EDSTUDENTED UNI, then my username and password (Message: success). Then I received the error message: invalid file or format.
Creo 8
Tested on Windows 10 and Windows 11 and on different hardware (64-bit)
Virus scanning and Firewall is off
How can I fix this?
Please contact academicsupport@ptc.com. You need to send them the Host ID (Mac address of the ethernet) and also the product code used. I hope they will send you valid license file.
Host ID ... this means physical address of network card
Same issue. Following.
