Installing Creo 4.0 licence problem
bostjan007
2-Explorer
I installed program normal, tried to run it and it was problem with licence. I red some of the conversations here and I uploaded the licence again. The message shows that this licence doesn't support this version. Please help!
4 REPLIES 4
if you want to use Creo 4.0, then
  • move current license file from C:\ProgramData\PTC\Licensing somewhere else
  • launch setup.exe from Creo 4.0 installation media
  • enter Product code
K-12       students can use Product code BE410708EDSTUDENTEDK12
University students can use Product code BK410705EDSTUDENTUNICL
Martin Hanák
SiBo
(To:MartinHanak)
Hi Martin,
unfortunately, I have the same problem.
I can not remove the old licence from Creo 2.0 on my computer. The folder is empty: C:\ProgramData\PTC\Licensing, but the licence from 2015 ist present.
The new licence is installed successfully.
 And Creo is not working, why? I ask for help. Thank you very much!
MartinHanak
(To:SiBo)
open Windows Explorer, enter C:\ProgramData\PTC\Licensing into its address bar and publish picture of Windows Explorer window.
Martin Hanák
SiBo
(To:MartinHanak)
I've already solved the problem. The solution was to delete all files from this path C:\ProgramData\PTC\Licensing. After that, I installed Creo again and the licensing works fine. Thanks for your help anyway!
